Hello everybody,
I'm trying to link an IFC file to my Revit 2017 project - but when I do so, the IFC file is linked far away from my model.
When I put the IFC in Navisworks or any othe viewer, my project and the IFC position match...
Can somebody tell me what I'm doing wrong ?
Thank you in advance,
Hi @Anonymous
Sorry to hear that you are facing issues.
Have you updated your Revit? See HERE for more information. Please install your updates from the Autodesk Desktop App.
Can you share a screencast and file if possible to test further?
I can send across a private upload link if you'd prefer.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thank you for your reply @Viveka_CD
Yes, I updated my Revit to 2017.2
The issue concerns only the linked IFC models. When I link DWG with the shared coordinates option, everything aligns perfectly - bearing in mind that the IFC was exported from Civil 3D model sharing the same coordinates.
Here's a screenshot of the issue.
