IFC import appearing as mesh
Message 1 of 11
We are having issues of steel beams being imported from IFC (created in AECOsim) appearing as a mesh in Revit 2018.
The beams are cell beams, so contain multiple penetrations through the web.
The meshing is occurring to approximately half of the steel beams. It's not obvious why this is happening to some but not others.
Replies (10)
Message 2 of 11
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!
Can you share a file to test further? Are you on the latest build of Revit?
Message 3 of 11
Hi Viveka,
Attached IFC and converted RVT.
Please let me know how you get on!
Ed
Message 4 of 11
Message 5 of 11
Viveka_CD
Hi @Anonymous
I will also need your diagnostic data to troubleshoot further. Kindly upload these files to test further.
Please see: Revit - Collecting and sending diagnostic data to Autodesk Technical Support
Let me know if you have any questions on the above and in extracting data required for diagnosis.
Looking forward to your reply update.
Message 6 of 11
Viveka_CD
Hi @Anonymous
Just checking back if you had a chance to send me diagnostic data for further investigation?
Message 7 of 11
Hi Viveka,
I've figured out Screencasts! Please let me know if you have any other questions.
Ed
Message 8 of 11
Viveka_CD
@Anonymous Can you please post the screencast link?
Message 9 of 11
Message 10 of 11
Did you solve the problem? I actually have the very similar question just as you.
Message 11 of 11
mengqi.huang
Hi Viveka,
I have encountered the same problem with certain geometries appeared as meshes once they've been exported as IFC and reloaded into Revit. Could you please update on whether this issue has been solved?
Many thanks!
