IFC export with 2 buildings in one project
Message 1 of 11
Hi all
I have a Revit file with 2 buildings. When I export this file to IFC, there is just 1 IFCBuilding in the IFC file. Does anyone know how can I have 2 IFCBuildings in the exported IFC file?
Cheers,
Maryam
Replies (10)
Message 2 of 11
Yien_Chao
easy : isolate the 1st building  before exporting to ifc, dont forget to enable the export only visible in view (i use 3d view). then repeat with the second building.
Message 3 of 11
Hi, thank you for your response but with this solution, I'll end up with two separate IFC files. I'm looking for a way to have 2 IFCBuildings in one IFC file. Is it possible?
Message 4 of 11
Yien_Chao
sorry lol i read the opposite 🙂
well in that case, a simple ifc viewer can federate your mutiple models. i use xBimXplorer.
Message 5 of 11
Apparently merging two IFC files is a bit tricky and it may cause some problems. Based on the structure of IFC, I should have two IFCbuildings so, why Revit does not export them as two separate buildings? There should be a way to this in Revit.
Message 6 of 11
Yien_Chao
wait, you have 2 buildings in one Revit file, but are one of them is a link? or does it have different phases?
Message 7 of 11
Both buildings have been defined in phase 1 and there is no link.
Message 8 of 11
Yien_Chao
Indeed this is strange, because it should work. Did you try any of the export template or use your own settings?
Message 9 of 11
I didn't change the default settings that much tbh. I just defined the phase and changed the space boundaries option since I need IFCSpace.
Message 10 of 11
Yien_Chao
Can you send a link to the file? I private message if that dont bother you.
Message 11 of 11
Sorry, I cannot share the file. I'm not the architect. I just need a proper export to IFC. I've seen this problem before but no solution has been provided.
https://forums.autodesk.com/t5/revit-architecture-forum/ifc-export-for-multiple-buildings-multiple-i...
