IFC Export for multiple Buildings (multiple IFC_Buildings)
Hello
Miy Situation is following. I have a modelled 2 independent Buildings in Revit 17. When i export to IFC there is no more seperation between the buildings as you see on the picture:
IFC_1.jpgIs there a way in Revit to have the buildings seperated? Like this:
IFC_Export_Frage.jpgThanks!
Viveka_CD
Hi @Anonymous
Can you post a screencast of your IFC export process?
Please confirm if you have the latest updates installed for your Revit version from the Autodesk Desktop app.
Viveka_CD
Hi @Anonymous
In addition to my previous post, I wanted to ask if you use the IFC exporter for the process?
I look forward to your reply update!
Thank you Viveka for your Answer.
Yes im using the latest Update for Revit 2017 and yes im using the IFC exporter
I need some time to do the screencast, because my Revit in the office doesnt have internet access, so i need to do it at home.
The thing is its a Model for a competition LOD200 and i wantet to keep all the buildings in one Revit Project, not doing one file for each building. So now i  know only one option to manually select each building and export it to IFC and then put them in an external sofware together. But maybe there is another way to get an IFC which contains each Building as seperated IFC Building.
best regards
David
