Project Location
Project Location
adam.purdyA2FPK
Project Location
adam.purdyA2FPK
Hello.
I have two different models and unfortunately the locations between these files are different.
Can anyone assist how i could relocate model (1) to replicate the location of Model (2)
Outcome for this is ill be able to copy and align to same place, between the Files.
I have tried relocating the project base point, even the survey point.
I'm also unable to simply move Model (1) into the Location of Model (2) as i have a number of design options and fully documented working drawings.
ennujozlagam
you ca refer to this LINK and see if helps. thanks
I might not suggest clipboard copy and paste. Instead I might Link Project 1 into Project 2, move Link Project 1 to the correct position and orientation relative to the Parent Project 2 Model, Publish or Acquired Coordinates, Record/Save Shared Position and Save Parent Project 2. After this, I would BIND & UNGROUPED Link Project 1.  Now it's a matter of deleting the Project 1 Elements what you wouldn't have clipboard copied/pasted over to Project 2 in the first place.  Now, if for any reason, you need to Link the Original Project 1 back into the Parent Project 1 multiple times, you can Link it in via Shared Coordinates and it will always land in exactly same location/orientation.
