IFC EXPORT PROBLEM
IFC EXPORT PROBLEM
IFC EXPORT PROBLEM
When i try and export an IFC from Revit 2017, nothing happens at all, so i have the 3D Window open. I click > Export > IFC > Choose my settings and location> Then click export. Then i get nothing, nothing at all happens. Can someone help, what am i doing wrong?
Viveka_CD
Hi @Anonymous
I see that you are a new member! Welcome to the Autodesk community!Smiley Happy
Can you confirm if you have the latest updates for Revit 2017?
  • I would suggest checking the Desktop App to see if there are any Revit updates available. For information on using the Desktop App see the following article: About the Autodesk Desktop App
  • Make sure to have the latest version of the IFC exporter installed as it has improved performance with these objects.
  • See HERE for workarounds for IFC export
Let me know if the installing the updates resolve your issue, or I'd be happy to test your file.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
