IFC EXPORT PROBLEM coordinate system changes
As a surveyor I need to export a model from revit into an IFC file. I ve set the project to the exact world coordinates using the survey point. including the datum to mark as Sea level. However as I export to IFC using the survey point as project origin, the IFC viewer shows the X and Y coordinates are flipped and one has gotten a negative value. The Z value is correct on the other handsurvey point export.jpg
If i export it using shared coordinates as project origin the X and Y coordinates are correct. But the Z value is that referenced to level 1 and not the survey points datum. so the Z value is wrong. How do I fix this?shared coordinates exportshared coordinates export
@Anonymous r.jarych
can you please send your Revit model survey point and project base point captured image
RJ
of course. Here they are in an elevation viewproject base pointproject base pointsurvey pointsurvey point
