IFC conversions of assemblies
teemu.kangasmakiRSGGS
We are developing our own bathroom pods in co-operation with our supplier. My idea is to make this pod as an assemble and deliver these assemblies for our designer to use in actual projects. Now that we operate via open BIM standards I have some issues with exported IFC:s.
When our architect uses these assemblies in actual project, all of these included assemblies have similar building story in IFC despite the fact that assemblies are in appointed levels in Revit. I´ve replicated this issue by inserting pre-made assembly in one level, then copied to others by "aligned to selected levels" function and the result can be seen in attachments.
Do you have any ideas how to work with this kind of issue? We, as a general contractor have the need to estimate quantities of every countable items and schedule those items per building stories. With this kind of result we have problems ahead.
L.Maas
Something similar came up recently. Check out THIS and THIS thread and see if it can work for you.
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks for the links to referring discussions.
I added a project parameter IfcSpatialContainer and as a Type of Parameter: Text and Group parameter under: IFC Parameters. With this enrichment I filled the names of the building storeys to pre-made assemblies - nothing happened, still the same. I tried to assign the IfcSpatialContainer also to the sub-components of the assemblies. Still nothing.
Is there something that I must do in IFC export settings?
L.Maas
Have you the IFC20xx addin installed?
Otherwise upload a small example of what you have in Revit and we can have a look.
Louis
Yes, I have the addin installed but I couldn´t get it to work on Revit 2018 BUT it worked instantly with Revit 2019.
I think that we´ll manage with this solution and promote our designers to use updated versions of Revit. Thank you for this solution!
JoshuamRivera
Only one POD or Assembly by itself can be exported and become a one element group.
RVT file with multiple assemblies will export them as parts (ungrouped)
Once the Assembly is created, open a 3D View to export to IFC. Go to File > Export > IFC to export the model. Model elements part of an Assembly are going to get exported as one element.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
