If statement
If statement
yes_and_no
If statement
yes_and_no
I have window trim profile at 3 y/n choices,
Profile = 2.5" (not a y/n, default)
Wide 3.5"
Wider 5.5"
My if and statement is not working,
Profile= if(and(wide, wider),(3.5", 5.5", 2.5")
Post a screenshot of your Family Types dialog box.
=if(and(Parameter A, Parameter B), Value if True, Value if False))
What the heck is the third value here?  =if(and(wide, wider),3.5", 5.5", 2.5")
David_W_Koch
Does Wider always take precedence over Wide or Default, and Wide over Default?
If so, then perhaps this will do what you want:
if(Wider, 5.5", if(Wide, 3.5", 2.5"))
If not, you will need to explain what you are trying to do in words, and someone here can help you translate that into a formula.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
yes_and_no
  • This is not good, this is EXCELLENT !!!
