Identify Location of Active Detail Components
BigPicture045
BigPicture045
I have a duplicate of a detail component that I need to delete. However, the detail component is being used in views and needs to be switched out with the other copy before deletion. Is it possible to view where this component is being used?
What more info is available under <Expand>? Any Element ID numbers that you can search for?
Create a Detail Items schedule, filter the family/type, and use Highlight in model to find out where each one resides.
BigPicture045
No element ID's. The detail schedule + Highlight in model worked well. Thanks.
