How to add a door to a generic model?
9 ANTWORTEN 9
Nachricht 1 von 10
tricelle.cummings
1060 Aufrufe, 9 Antworten
I created a generic model and I need to add a door to a few walls, however it will not place, any suggestions?
9 ANTWORTEN 9
Nachricht 2 von 10
rxi.gg
als Antwort auf: tricelle.cummings
I don't understand what are you referring to
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 10
tricelle.cummings
als Antwort auf: rxi.gg
I created a generic model family and I need to add a door to my family, but it won't place. I think it's because I chose generic model when cresting instead of generic face based or generic wall based.
Nachricht 4 von 10
tricelle.cummings
I am creating a family and I chose generic model to model a structure, however I need to add a few doors and it will not place. I figured it's because I chose generic model, is there a way to place the door in the walls?
Nachricht 5 von 10
Doors can be added only to walls. If you are going the route you are going with, I think the way to do this is this:
  • Create a void cutout in the generic family size of the door and frame
  • draw a wall in that void
  • add a door to that wall, and the door with the frame will take up the entire length of the wall making it disappear leaving you with a door in your generic family
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 6 von 10
Thank for the suggestion! However I forgot to mention that the walls are extrusion with parameters. Is it possible to add doors and windows without having to recreate this structure in a new family category?
Nachricht 7 von 10
So I played around with what you are doing, and this is what I came up with.
  • Create another generic family which will be with the size of the cutout. See pasted image, I made a red block for my generic "cutout" family
  • Place where you want the cutout to happen (can be in multiple locations)
  • Go to ribbon -> modify tab -> Cut and select both families (The one cutting and to be cut)
  • Hide the cutting family (my red block)
Nachricht 8 von 10
Thank you
Nachricht 9 von 10
luke.johnson
I believe you could use this method to create a kind of super family that has a variety of nested components including doors:
https://wrw.is/save-in-place-family-as-rfa-for-use-in/
Luke Johnson
Nachricht 10 von 10
You can change a wall based door family to a face based door family then you will be able to place it in the generic model family.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-cha...
