I cant see the 'fine' detail in my roof type
17 REPLIES 17
Message 1 of 18
1650 Views, 17 Replies
Hello
I'm working in REVIT 2022 full and have a template set up for fine detail while I'm drafting my views.
My floor and wall types are showing up perfectly with the makeup of the element, however my roofs are showing as a solid black fill.
I have check that there's no overrides in the template and that roofs are set to 'fine' but I don't seem to be able to get to the bottom of the issue. Any ideas?
Excuse the junky model - It's a work in progress
Tags (1)
Labels (1)
17 REPLIES 17
Message 2 of 18
syman2000
Can you check in the filter to see if there is filter set roof to cut set to solid black.
Message 3 of 18
Looks like the Coarse Scale Fill/Color of the Roof Type.
Message 4 of 18
in reply to: syman2000
Great idea but unfortunately not
Message 5 of 18
in reply to: barthbradley
That's what I thought but its set to 'fine' and I've got no pattern set when it is course
Message 6 of 18
syman2000
Also check if the roof is set in the correct phase or you can set the phase to show complete instead of show all.
Message 7 of 18
Graphic Overrides by Element?
Message 8 of 18
I thought that too - unfortunately my phasing's fine and there's no change if I set it to new.
Message 9 of 18
Nope - not that either unfortunately
Message 10 of 18
syman2000
Check @barthbradley suggestion. If nothing works, please upload the sample so we can analysis the issue.
Message 11 of 18
Well that's frustrating - If I copy a little of the model to another file it SHOWS so I must have something set incorrectly in the project. I've deleted out most of the project but the view I'm referring to is Section AA
Message 12 of 18
Do this test.  Copy and paste aligned in place the section line, open the new section view and tell us if you still see the roof section poche.
Message 13 of 18
in reply to: ToanDN
Yep - I can see it in a brand new project - just not in the master model. I uploaded a small piece above
Message 14 of 18
syman2000
When I look at the view, seems like it has solid fill applied and set to course. I removed it and it works. I double click to access the view and then use VV shortcut to make it show.
Message 15 of 18
Ok totally confused - I cant see one in my model at all in exactly the same view........ I'm sure this is horribly simple and my inexperience is complicating the issue. Sorry.
Message 16 of 18
syman2000
Did you double click into the view? Sheet also has it's own visibility and graphics but that won't fix the problem. So you select the view and right click to activate view. You should see the titleblock being greyed out. Then do VV shortcut and you should be seeing the setting where roof is has solid black cut and set to course.
Message 17 of 18
RDAOU
@Anonymous
  • Did you try to place another section and check if roof looks fine there? if that is the case, create a view template from the view that looks fine and apply that template to the offending view
  • Did you check Default Roof Material under Object Styles?
  • If not the above and you have assigned different material to the roof layer(s), did you check the Material Graphics setting (Cut Pattern)
Message 18 of 18
I am not talking about copy paste it to a new project.  Copy paste the section within your own project and tell us how the new section looks?
