<Hi
href="mailto:eviele@dimellashaffer.com">eviele@dimellashaffer.com>
wrote in message
href="news:6083278@discussion.autodesk.com">news:6083278@discussion.autodesk.com...
all, Attached is an image showing how our reveals stop above the door. They
didn't always do this, but we've recently changed the level elevations due to
a change in grade. Since that move and since fixing a few wall errors we now
have the reveals stopping above the door. We're not sure why and I'm out of
ideas, any advice to get our reveals to be continuous? Thanks. Eric
Can you post a screen shot of the wall AND of your reveal settings?
How is the reveal's profile defined? Is the reveal part of the wall type settings?
Normally the reveal should be continuous above a door or window.
I guessing maybe he has a SINGLE reveal defined, using a Profile containing several little rectangles. So if it gets cut at its placement point, it cuts all the way up.
The solution, if that is the case, would of course be to define several separate reveals using a profile containing a single rectangle.
That's correct. I'm using a single profile with multiple voids. The weird thing and the reason I'm asking about this is because there are no issues with this over windows, only above doors. And yes, I did end up using single void reveals above the doors as a patch. So I guess my question is: what is it about the doors causing this? I don't see any differences in family properties between doors and windows that could be causing this. Thanks all!
I don't know this for certain...I just suspect it.
Your single profile with lots of reveals contained within it is probably drawn up from the horizontal plane, and within the wall structure the reveal is probably set to be placed 0' from the base of the wall (or at least very low) right?
So the doors (and the curtain wall) are cutting the "insertion point" of the reveal, but the window, which doesn't sit at the bottom of the wall, does not cut it. I suspect this results in the behavior you have.
Possible solution is to build the profile DOWN from the horizontal plane, and then in the wall structure set it be placed an appropriately high distance up from the bottom of the wall, or maybe even a low distance down from the top of the wall. In this way the "insertion point" will be up high such that neither the window, the doors or the curtain wall will be cutting it.
Or just do a single reveal in the profile and then set it up in the wall structure to have lots of instances.
@ToanDN wrote:
Good guess. Then the fix is easy by set the Base offset to below 0
Ah yes, that would work too. Regardless of how you adjust the "insertion point" to solve the problem, you would just have to adjust your Profile sketch to suit it so that you get what you were aiming for in the resulting wall.
I ran in to the same problem with a large reveal being "interrupted" by a door that crossed it's path. Another quick fix I found is to set the door sill height just slightly above the level, say 1/32". This works for a short term fix, but I think it would throw off the door schedule.
