I cant copy Levels from a Linked model using Copy/Monitor
Damjandobrovic
Observer Observer
Damjandobrovic
Observer
Observer
I am currently working on a project that consists of 3 Revit models containing residental and commercial buildings. Each of the 3 modely has its own Levels, and what Im trying to do is to make a separate model containing all the Levels in one place so we could use the Levels from that model in Revizto for our project.
When I try to use Copy/Monitor to copy the needed Levels I get a couple of errors and warnings, most of which I can resolve, but at one point I get the "The top of the Wall is lower than the base of the Wall." error and I can only cancel the command.
I was wondering if there is any way to get around this problem or any other way to get all the Levels in one place ?
vitorbortoncello
i don't know exactly wich option you are using to copy..there's this post if helps:
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-E6084898-32EC-40AF-87AF-F2F8A8737101
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
