I cannot select view on a sheet. How can I reactivate them?
svalente9GJKH
Message 1 of 18
svalente9GJKH
I have several views setup on a sheet I cannot select them for editing. Normally I would double click on them and be able to make edits. it seems that the titles are also gone. How can I be able to edit these views?
Thank you
Replies (17)
Message 2 of 18
RobDraw
If they are not selectable, they may be pinned and you've turned off selection of pinned elements.
The view titles could be related to the viewport type.
Sharing an example file or at least some screenshots that illustrate your issue could be helpful.
Rob
Message 3 of 18
Perhaps the views are pinned and you have disabled Selection of Pinned Elements.
Message 4 of 18
The View Titles are gone?  You sure you didn't accidently double-click on the Titleblock and open the Titleblock Family?  Yah; sounds silly but it's a possibility nonetheless.
Message 5 of 18
svalente9GJKH
Still can't get it...
Here is a screen shot, its all the detail views on the left:
Message 6 of 18
Can you show a screenshot of this area?
Message 7 of 18
Mike.FORM
When on your sheet turn on the little light bulb (bottom left corner) to reveal hidden elements. It is likely the view has been hidden. When you hide a view on a sheet it is still visible but you cannot select it. The indicator is that the views no longer have a view title visible.
Message 8 of 18
svalente9GJKH
Seems like you are on to something,  the views appear hidden.   Although when
I try to unhide, it is greyed out and not an option.  How do I unhide the views?
Message 9 of 18
Sounds like the view is both hidden and pinned.
Message 10 of 18
svalente9GJKH
so what would I do?  I'm not seeing seeing how to unpin or unhide...
Message 11 of 18
See the post where I asked you to show an addition part of your screen.  Show it.
Message 12 of 18
svalen
Oh sorry, here it is:
Message 13 of 18
It looks good, thank.  Without the file to figure out the root cause, I would just go ahead and fix it by right clicking on each view under the sheet in the browser and remove it from sheet, then place them on sheet again.
Message 14 of 18
svalen
ok this works too...thank you
Message 15 of 18
Duncan_Huggler
Community Visitor
Community Visitor
Big thank you! Similar problem.
Message 16 of 18
j103-kiruba
Community Visitor
Community Visitor
Message 17 of 18
SAINA02
This article is such a gem.
We had the same problem. One of draftsmen had tried to hide the floorplan in the sheet, and left it like that. We used the lightbulb solution and then unhide.
Message 18 of 18
jcarwood
Thanks for this post - saved 4 of us hours of headaches - hidden viewports GRRRRRR!!!
