Just when I began feeling a little comfortable using Revit this issue got me feeling dumb again.
I got an Revit Model from an architect for coordination and the first thing I did was to print a full set of drawings from the sheets they created in the model. Then I began digging around in the model and I noticed that some of the Plan Views that were used to create the sheets are not in the project browser.... or at least I cannot find them. Is there something I'm missing here? I'm at a total loss.
Solved by constantin.stroescu. Go to Solution.
Solved by TripleM-Dev.net. Go to Solution.
Project browser organization has them propably filtered out.
See image below, change to builtin ALL scheme.
- Michel
in Project Browser >Browser Organisation ....It has been used a custom organisation scheme that has a Filter like this applied :
Now , either remove the Filter, or choose another organisation scheme as was already suggested - All for instance..
Constantin Stroescu
