I can't set the hatch
Message 1 of 8
I can't set the hatch in material option when I want to build wall or the other elements . In graphics I haven't this option. Maybe my software need upgrade or something other? Please help my!!! I enclose screenshot. I've revit 2014.
Replies (7)
Message 2 of 8
angelica.rodriguez.3d
Is that happening with one material only? Or is it accross all the materials?
Could you try to create a new material and see if the same thing happens? Try changing the material identity to a different category and see what happens. If not luck, you better make sure you have the latest service pack for Revit.
Message 3 of 8
Its the type of material you have chosen. duplicate one with a material and then change the material hatch for that one. That would be the simplest way.
hope that helps.
Message 4 of 8
It concerns all the materials. Create new material or changing the material identity to a different category, don't help. Do you know how can I check that I've the latest service pack for Revit?
Message 5 of 8
When I duplicate something the same is happening.
Message 6 of 8
Message 7 of 8
try downloading this - i think its the same material you are trying to use.
https://we.tl/IADu0ljULd
to load it in go to material browser. Go to the home button and open existing library and load the file attached. Let me know if you see all the shading options etc.
Message 8 of 8
Ok I found solutions. In aplication programs and functions clicking one on Revit 2014 and leter clicking deinstalation/chenching. Next clicking add or deleate components. Next mark everything in our language and install. Its help me.
Lower screenshot.
