This is also a Windows error. May not be a Revit related.
BTW: You're the second one to post about this particular issue today. Strange.
it doesn't have to be antivirus (u should consider using one though), it is something which is infuriating Revit from writing/accessing the shared location where data is brig saved... It can be any of the following reasons
for us to be able to help u or give you specific suggestions you need to be more specific on the kind of setup u have, which revit r u using and which build, what were you doing when error occurred (working locally or on a network)
- Do you have all service packs / updates for revit installed?
- Did you recently update windows?
- go to Revit Application menu >> Options (or alternatively in the revit.ini) and check the path set for default saving of documents...make sure you have the right access to that folder.
- shut down revit then restart by right click on desktop icon and run as administrator
unfortunately still the problem : my internet is local and everything okay but still the problem 😞 and my windows is 10 and i'm checked the firewall everything is good but i don't know why also i'm delete it and install again but the problem still plz anyone can help ?
I have the same issue. Windows 10, up to date, Revit 2017. I cannot save a file. It is not limited to one file. I have repaired Revit installation. I have turned off Windows Defender real time protection. I have uninstalled Malwarebytes...still no go. Any other ideas? Thanks.
