I can't rename views in project browser
Message 1 of 42
Up until Revit 2020 was easy, just clicked on the view and rename it directly or choosing rename
But now in Revit 2021 it is imposible. I don't have either options
Could someone explain to me what do I have to do?
Replies (41)
Message 2 of 42
PavelAnd
Hi @Anonymous! Is this problem found on only one computer? I have not such problem. Try reinstalling Revit...
Best regards, Pavel Plotitsyn.
Message 3 of 42
hmunsell
when you select the View, can you edit it in the Properties pallet under View Name ?
Howard Munsell
Message 4 of 42
When I go to the rename option the view just keeps blue but I can't write anything.
I can duplicate, or whatever but no rename. Weird
Reinstalling Revit ? Shame
Message 5 of 42
No.
I will try reinstalling 😞
Message 6 of 42
hmunsell
ya, that's weird. like @PavelAnd said, it works fine for me too. cant think of anything that would prevent that function either.
Howard Munsell
Message 7 of 42
Nope.
Unistalled and then Reinstalled , but it is the same
😞 any other solution ? anyone ?
Message 8 of 42
hmunsell
can you upload your model so we can take a look at it? lets see if we have the same issue. could be a file issue, could be a PC issue.
Howard Munsell
Message 9 of 42
Well , it is something weird. Never happened since Version 6
The only way of renaming any view is through Sheets
When I place an image in sheet I can rename it with (in) the viewport (title)
Well, I will be waiting if someone knows something new about it
Message 10 of 42
RobDraw
It might be a long wait unless you share the model as suggested.
Rob
Message 11 of 42
Fakerobert
Same here, i can't rename anything in browser
Message 12 of 42
No issues here.
Message 13 of 42
Do you guys have RENAME in the Right-Click Menu?  Is this just about the single-left-click, direct Renaming not working?
Message 14 of 42
Thank you  @RobDraw @barthbradley @ToanDN @Fakerobert @hmunsell but it is not one project
Left click gives the option, gets blue, but I cannot change it
In anything that I open.
When I open a template is happening, or any project
Same everywhere no way to rename any view
Message 15 of 42
At least I'm not the only one 😞
Message 16 of 42
Try starting a New Project with a different Template and see if you can rename in that one. Report back results.
Message 17 of 42
RobDraw
Could it be that cursed cursor thing?
Rob
Message 18 of 42
Cursed cursor???  You mean like a witches' hex?   Try Norton's "Hex Removal" software.
Message 19 of 42
I have tried all templates, clean installation
Well I will have to live with renaming into the sheets situation
apparently is my computer, because for all you guys is working
Well, thanks
Weird that it is the only thing that is not working
Message 20 of 42
RobDraw
Wait, you didn't answer my question.
Does it work if you make sure the cursor is in the box?
Rob
