Hi... I am having trouble with this wall... for some odd reason, it doesn't want to unjoin from the ceiling... I tried enjoining the parts with the unjoin up/down command, I tried unjoining them via the normal join command, but when I look at the properties and there is this:
translates to "Upper part is joined" and it's ticked but Its grayed out. What do I do
Solved by ToanDN. Go to Solution.
Select the wall > Detach Top/Base > Select the ceiling (or click Detach All button if you want to to detach it from everything else).
It should unless you are talking about something else. Try again, or share the file here I do it for you.
Just figured it out... Instead of Unjoining them, I needed to join them at the base/top... a rather unusual fix but it worked... thanks!
