How to unojin wall from ceiling
4 REPLIES 4
KristianPocsik
502 Views, 4 Replies
Hi... I am having trouble with this wall... for some odd reason, it doesn't want to unjoin from the ceiling... I tried enjoining the parts with the unjoin up/down command, I tried unjoining them via the normal join command, but when I look at the properties and there is this:
translates to "Upper part is joined" and it's ticked but Its grayed out. What do I do
Labels (3)
4 REPLIES 4
in reply to: KristianPocsik
Select the wall > Detach Top/Base > Select the ceiling (or click Detach All button if you want to to detach it from everything else).
KristianPocsik
in reply to: ToanDN
Tried that, does not work
It should unless you are talking about something else. Try again, or share the file here I do it for you.
KristianPocsik
in reply to: ToanDN
Just figured it out... Instead of Unjoining them, I needed to join them at the base/top... a rather unusual fix but it worked... thanks!
