how to turn off Original Symbol?
rlinpager
rlinpager
They showed up on my project after updated 2020.2 revit. I cant figure it out how to turn them off?
hmunsell
this has been an issue since the last update.... please read the forum linked below.
https://forums.autodesk.com/t5/revit-architecture-forum/internal-origin-problem-after-update/td-p/91...
Howard Munsell
Yeah, there has been a lot of threads on this topic over the past couple of weeks.  This 2020.2 change has caused some confusion and grievances.  Additionally, note that the project base point clip has been removed. This will probably bake your noodle as well.
You might find this now necessary as well:
http://revitoped.blogspot.com/2019/12/internal-origin-follow-up.html
Thank you Autodesk for necessitating the extra work.  Sarcasm intended.
s.borello
Go to visibility graphics_site then un-check Internal Origin.
