Hi all!
I've done a couple of renders in Revit in "Best" quality setting, 300DPI.
The render comes fine.
Now I need to do some minor amendments on the project, so I shot a render in REGION, with the same settings, "Best" and 300DPI, only on the portion of the view that has been changed.
Why the render that comes out is blurry and totally different from the quality of the first render?
I'm 100% sure I didn't change nothing from the previous one!
The camera clipping plane needs to remain as it was before. With Revit 2016 I simply render few regions of the entire view and add them on Photoshop to update the view... I don't know why it's not possible anymore.
However the camera clipping plane is large, 600mm the longer side... It's a very waste of time if I have to render every time the full view even if there's a minor amendment.
