Hi
How can I tag a 'length' parameter, see below. in the tag family there is no parameter 'length' to create a label from.
Hi
Solved by Kimtaurus. Go to Solution.
You have to create the Length as as shared parameter in the family, then use that parameter for a Label of the Tag. Speaking of which, I don't think you can tag detail items. Maybe use a custom dimension that hides the lines and only shows the value.
Follow @ToanDN instructions to create an extractable parameter (tags and schedules).
You can create a Detail Item Tag.
Create new family, use the Generic Annotation template. Next change the category to Detail Item Tags.
Create a label, using the Shared Parameter you using in the detail item.
I might be way off base here in understanding what you are trying to do, but there is a nice video by Alfredo Medina on doing this for a line based family that reports the length.
https://www.youtube.com/watch?v=gqIvwwmQ0ME
There is also a sample file on the Autodesk Help here, (just scroll down a little, looking for "Two pick family to calculate fire exit distance"):
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-DEADF731-AD3F-47F8-B2C8-B31341CA0C5F
This video was useful Thank you.
I basically made a detail item and a shared parameter that will allow me to go from A to B on a piece of wall and take off the length. I need to take a particular length of wall to be used in bracing calcs for earthquake and wind.
Thank you
Thank you
