How to slope a roof 2 ways?
dcsank
Message 1 of 17
dcsank
I need to slope a roof 5 degrees one way and 5 degrees the other. When I try to do this with define slopes, it creates a ridge or hip where the 2 slopes meet. I want the whole roof to continually slope in both directions. It has to be roof because its actually a canopy system and I'm using curtain walls and I need the curtain wall grids to still be 3' orthogonally apart from bird's eye view
Replies (16)
Message 2 of 17
EATREVITPOOPCAD
5 percent = 0.6" / 12"
To do this do the following:
  • Architecture tab -> Roof button -> select level -> draw a rectangle
  • Select 2 of the lines and uncheck the Define Slope checkbox
  • select the lines you DID NOT select in the previous step, and enter a slope of  0.6" / 12" in the properties (It will change it into a fraction after you enter)
The definition of insanity is doing the same thing over and over again and expecting different results
Message 3 of 17
dcsank
Yea this exactly what I did at first. It creates a ridge or hip where the 2 slopes meet (also 5 degrees can simply be entered as 5 in slope). So imagine a plane - I tilt it 5 degrees one way first then tilt the whole thing again 5 degrees in the other direction - this is what I'm trying to achieve
Message 4 of 17
EATREVITPOOPCAD
Ah I see, Thanks for teaching me about the % input never knew!
I would create an in-place mass (or a plane technically) and then use the roof by face command.
Message 5 of 17
dcsank
I think I just found out how to do this although the gridlines don't look precisely orthogonal. I followed a reply here: https://forums.autodesk.com/t5/revit-architecture-forum/roof-slope-in-2-directions-with-the-same-ang... with the crazy equation = 2*tan(8.0°)/SQRT(2) and I changed it to 5 degrees. Then I had to rotate the gridlines 45 degrees. Works but if someone else has a better solution let me know - thanks
Message 6 of 17
Create a bigger roof rotated 45 degree with one way slope, enter this formula to the slope =5*pi()/180*sqrt(2) , then use a vertical opening to cut it to shape.
Message 7 of 17
RDAOU
@dcsank
See GIF below
Use a Mass in Place >> Apply roof by Face
Message 8 of 17
You might have an easier go of it using the Roof by Extrusion Method.  Food for thought.
Create a Roof by Extrusion | Revit 2020 | Autodesk Knowledge Network
Message 9 of 17
dcsank
I know need to slope the roof 5 degrees in one direction and 10 degrees in another. I still want to create the roof like I outlined in my last response but need a different formula.
Message 10 of 17
Can you be a little more descriptive? Explain what you are trying to do now.  Maybe include some pictures.
Message 11 of 17
dcsank
I made exactly what I want in terms of sloping in a roof using simple trigonometry for inputs for the points below but this can't be changed to a slope glazing type. So now I need a formula that can do this to use as slope within the footprint edit tool
Message 12 of 17
Within the footprint sketch? Why don't you make a parametric Mass to Host the Sloped Glazing to?
Message 13 of 17
If you already have the roof above modeled, then simply create an in-place mass surface based in that roof, then create a curtain system by face from the mass surface.  If you don't know how, share the file here.
Message 14 of 17
Sidetracked
A simple work around is to create a floor with the same properties, materials etc as the roof then use modify sub elements to add calculated elevations to the corner points.
Message 15 of 17
colinqBYUV9
Simplest way by far is to include a slope arrow. No need for anything tricky, just need to know the pitch angle and the direction of the pitch.
Message 16 of 17
Sidetracked
Very hard to do with a slope arrow if you are wanting two different pitches and the roof is rectangular not square. Didn't realise but you can edit a roof the same way as a floor by way of modifying sub elements.
Message 17 of 17
SteveKStafford
Saw your replies and then realized this thread is almost exactly a year old 🙂 I was thinking the same thing with a slope arrow. I just experimented with slope values until the slope annotation reported 5 degrees (really 4.96 but rounded off). For a rectangular roof (not square) we'd just have to calculate the fall for each side that "mattered" and then plot out the slope arrow in the direction the roof would "fall". A bit tedious but doable.
Steve Stafford
