How to show same items in schedule as just one line and show the number of these items?
seutaojiang
seutaojiang
HI  I wonder how can i  show identical items with same dimensions in a schedule  in just one row and show the number of the items  ? Right now in my revit file each item is showing in a row and many of them are identical.  Please see the attached files.
Thank you very much!
azad.Nanva
in Sorting?Grouping uncheck the Itemize every instance.
Or:
seutaojiang
HI I want to show the different length of the same type in different rows. If I use your solution, there are many types are "variable" and not showing the actual length of the components.  Is there any way I can list the different sizes of the same type in the schedule?
artur_dobriyan
You can in schedule and after filters choose parameter where you have a variables and filter it out as you want and it must do the trick.
azad.Nanva
