Handrailing in stair modeling
6 ANTWORTEN 6
Nachricht 1 von 7
rishikeshavan2B9L4
374 Aufrufe, 6 Antworten
in edit modein edit modeHii guys please find the attached images of staircase and handrailing  where i have problem with handrail model continuity  can any one help me with this problem to solve the stair problem.Stair hand railing continuity problemStair hand railing continuity problem
Tags (1)
6 ANTWORTEN 6
Nachricht 2 von 7
you have to edit it manually, double click and edit path
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 7
als Antwort auf: rishikeshavan2B9L4
Post your file here.
Nachricht 4 von 7
Mike.FORM
Ctrl+C the railing and paste aligned to the same place. Then edit each railing path and remove the path lines making the inner segments from one of them and in the other remove the path lines making up the outer segments.
Then repeat this process for the 3 different levels.
Nachricht 5 von 7
rishikeshavan2B9L4
als Antwort auf: barthbradley
Thank for replying please find the find that i have attached
Tags (1)
Nachricht 6 von 7
rishikeshavan2B9L4
als Antwort auf: Mike.FORM
thank you i tried it did not work.
Nachricht 7 von 7
thank u i tried it did not work
