How to show full views in elevations and plan?
I cant figure out how to show the whole vies while in elevations or roof plan.  How do I change the view area? in both roof and elevations?
ennujozlagam
@Anonymous hello, what do you mean? can post some screenshot. Or are talking about crop view / crop region visible untick them. thanks
kadmonkee
view range controls the depth of a plan or Reflected ceiling view
crop region manages the plan views limit for both modeled elements and Annotative elements
Section boxes control the depth of 3d views
Far Clipping controls the depth of an Elevation or Section view
all of these settings are found on the properties Palette under Extents for each view type
the blue highlighted lines display the limit of my plan view the blue dots are for adjusting the overall size of my view limits.
the dashed line displays the limit of my annotative area.
the images below display the Far Clipping area of both a section and an Elevation the dashed line limits the distance you are looking into the building
the section box defines the limit of a 3d view as displayed in the image below note the blue highlighted lines and the directional arrows which allow you to flex the size in all directions
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Viveka_CD
Hi @Anonymous
Just checking back to see if the recommendation by @ennujozlagam and @kadmonkee help resolve your issue?
If you can share a screenshot, it will help us dive in to see whats happening at your end.
Looking forward to your reply.
