How to set view option so that the reinforcing bars are not visible inside con'c
kcmc_bim
kcmc_bim
bin
Select the Rebar, Edit the View Visibility States.
kcmc_bim
I tried applying the view options you told me but it doesn't solve the problem. (As shown in figure r1)
I want a view option that doesn't show the bars inside the concrete. (As shown in figure a1)
bin
Can you share your Revit file please?
Turn off the Category then.  If you are uncertain of the Category, then select one, right-click mouse, select Override Graphics in View=>By Category from drop-down.
bin
Unticking this will hide the part in concrete.
kcmc_bim
Changing the view option to the method you said 'Unticking this will hide the part in concrete' solved the problem.
Thank you so much.
