SKP link / import material override
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
76jsa
1026 Aufrufe, 2 Antworten
I have linked .skp file to Revit. I want to override material of the imported model or leave it  as it is in Sketchup, Revit shows that as grey (picture)
In Object Styles overriding works only for lines, but when I try to change the material there - still looks as it is as imported.
2 ANTWORTEN 2
Nachricht 2 von 3
bin
als Antwort auf: 76jsa
I tried the Object Style and it doesn't work...
But if you applied materials to the building in Sketchup, you can find those materials in your Materials and change the materials there.
Nachricht 3 von 3
76jsa
als Antwort auf: bin
Works okay, but i is silly, that you cannot overwrite it globally...
