How to set objects' colors to another level
okutany
okutany
Hello everybody,
I am coloring my objects by filtering in one level. However, I want to see these changes in another levels as well. Let me show you.
In the first image I colored all walls, columns etc in Level 1. As you can see these change doesn't apply on level 5.25. How can I make it automatically?
Thank you all..... o/
se.ha
Hi @okutany,
the easiest way would probably be to create a view template from Level 1 and apply it to all the other views:
Create a View Template | Revit | Autodesk Knowledge Network
  1. In the Project Browser, select the view from which you want to create the view template.
  2. Click View tab -> Graphics panel -> View Templates drop-down -> Create Template from Current View, or right-click and select Create View Template From View
Be careful though, if you have hidden certain model categories or annotations in Level 1, these settings will also be applied to the other views.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
