I'm trying to create a RCP but when I click on my ceiling view all I see is a box. Everything looks fine 3D view. I've already checked visibility graphics and I've tried playing around with view constraints. Please, any suggestions??
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von se.ha. Gehe zur Lösung
Hi @chiomaun94,
maybe check the phases/phase filters in this view or design options?
Is the box an actual box/floor or is it the crop region? If it's the crop region, try turning it off.
Could be a bunch of things. Since it's "just" a Midterm Project consider uploading the file and letting us have a closer look.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
I'm with @se.ha on this. I suspect Phase is set wrong.
FWIW: Keep this list handy. It'll help you troubleshoot things like this.
Did you check to see what the box is?
