How to rotate call out outline
AidanHawkins
Message 1 of 9
AidanHawkins
Please see image
How do I rotate this call out boundary ..
Replies (8)
Message 2 of 9
Rotate the view crop region.
Message 3 of 9
AidanHawkins
yes but is there any way of doing this without having to rotate the whole view itself?
That is what is happening
It wont let me rotate the crop region like in a regular plan
Message 4 of 9
526996629
Use a scope box
Message 5 of 9
AidanHawkins
Message 6 of 9
526996629
1. use a scope box to crop the view where you'd like to call out. Let's call this 'view 1'
2. Draw a callout and select 'reference other views', select view 1
Message 7 of 9
AidanHawkins
Okay great thanks for that
And how can I make sure my call outs are created at 1:100 instead of 1:50? Every time I create one it turns it 1:50
Message 8 of 9
526996629
If you are using the call out view, then just directly change the view scale after you create it.
If you are using the reference view, then change the view scale of the reference view.
Message 9 of 9
526996629
If you want the default scale to be 1 to 100, just set a view template (where you can set the view scale) for the call-out type
