How to rotate a Face based Family to a perpendicular Reference Plan
stingers80-cgarchitect
Message 1 of 9
Hi Everybody,
I have this Generic Face based family which was created by someone else.
It is annoyingly created perpendicular to the face it is meant to attach.
I can't rotate any of the objects or change their orientation to be on the Face it is meant to be.
I can't rotate their Host Plane even while editing their shape (e.g. sweep)
I tried copy and pasting the objects to a new family but they all appear on the same orientation as they are created.
Any ideas?
Accepted solutions (3)
Replies (8)
Message 2 of 9
kadmonkee
change the orientation and origin in the family itself
if it needs to be on an elevation view manually set it in the family editor
currently it is set in a plan view, so change it to a left or right view orientation.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 9
Post the family. We'll fix it.
Message 4 of 9
Here it is.
This one is not a complicated one so one way I found is to individually change host of masses in 3d view. I was wondering if there was easier way without the need to put back all the objects together after Re-hosting.
Message 5 of 9
Like this?
Message 6 of 9
Just rotate it on the side elevation.
Message 7 of 9
@stingers80-cgarchitect: Did you not like the family I posted in #5?  Just curious why that one didn't work for you.
Message 8 of 9
I'm sorry. I didn't realize there were 2 replies. I only saw the last post with the family. It worked. I don't know how I wasn't able to rotate them from side view. It seemed that they were locked.
Thanks for help.
Message 9 of 9
Thanks for help.
You need to check Disjoin box when you rotate it.
