How to retrieve the orientation of windows ?
- Mute
- Permalink
- Report
The orientation of windows is important for the heating and cooling of the building.
I can make a schedule with several parameters of windows, but I don’t see an orientation parameter. Cheking the orientation of each window individually would be a lot of work. Less slow would be to add a the parameter orientation to windows, type it in for each window (based on the wall it is in) and then add that parameter to the schedule. Perhaps faster is to create a plan view that shows only and all windows and start from there, perhaps by continuing with the previous.
However, is there an efficient way of getting the orientation ?
Inclined windows are more complicated, but there are few of those.
I am holding off on trying the plugin suggested in forums.autodesk.com/t5/revit-architecture-forum/revit-architecture-2015-wall-openings-area-amp-orien... as at first sight it doesn’t appear to do what I want.
