Array with lenght parameters
danielfgpontes
danielfgpontes
I'm trying to make a family with lenght and width parameters, the family alone works just fine, but in the project when used with array, only works right with the original lenght (400cm), if I use array then edit the lenght to 450 cm the elements goes overlapping each other and if I put 300 cm the elements goes spacing between each other.
There's some way to make lenght parameter works properly inside array?
_Vijay
you better create the nested family with length parameters associated with the current family. try like this or share your family for triels.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
RDAOU
@danielfgpontes
The length, as it is in the family, is already working properly. As it is, the array and the width exist in 2 different environments. When you load the family into the project (as you have mentioned) there is no relation between the ARRAY and the WIDTH/LENGTH of the window. Meaning every time you change the width of the window, the you will need to change the array.
Two options:
  1. USE FAMILY BASED ARRAY: Nest the window geometry into another window or wall based generic family and do the array therein. when constrained properly you would be able to control the Array, the offset and the window Width using 1 input...
  2. USE GLOBAL PARAMETER IN PROJECT ENVIRONMENT TO CONTROL GAP BETWEEN ARRAYED INSTANCES:
    • The width parameter of the window (preferable) Instance parameter - to avoid type change in a group (Note: the default width parameter in windows template is a Type. You will need to create a new width parameter and set that to instance)
    • Associate it with the Window Width Add a global parameter "WinT1_Width" and
    • Add a global Parameter name it "WinT1_Gap"
    • When using array: Make sure that new group instances append to END (check box is available in options bar when selecting the array ctrl)
    • lock/constrain the Center/Mid of the first two instances of the array to 2 reference planes. Use reference planes because they are more likely to respect constraints (pin the first to control the direction of the array)
    • Associate the distance between the 2 reference planes to a global parameter name it "WinT1_CTRL" and use a Formula = WinT1_Width + WinT1_Gap
    • See below  GIF capture for a better understanding on how it functions
Constraining an Array in a ProjectConstraining an Array in a Project
danielfgpontes
@_Vijay  @RDAOU
I tried making a nested family (the easiest way, because I will need do this process several times) with my component but don't worked, when i change the lenght in the nested family it doesn't apply to the original geometry family but the parameter value in nested family still changes.
Here my source family (Revit 2021), not the nested one:
RDAOU
@danielfgpontes
Check the following youtube. I made a slight modifications to your original panel family (category changed to Generic, added Height and Material parameters and modified some reference planes.
  1. It is a line based array, in the model you place it by specifying start and end point.
  2. The array concatenates panels of a given length (user input) along a given path.
  3. The family will add a cut piece at the end of the path if required
  4. The cut piece is added if the end gap is greater or equal to 700 (assumed minimum length of a panel)
While you have specifically asked about arrays, There are easier and quicker Alternative methods to create such elements:
  1. Model the family as a handrail panel and use a handrail
  2. Model the family as a curtain panel and use a curtain wall
Albert.Maduro
I want to know how do you make that gif
hoda.ganji
Would this help? "Modular Construction 5, Array Parameter, Revit": https://www.youtube.com/watch?v=pg3q_E1HBOw&list=PLnQTukI1DJvyfNBksQhmhyayQuJn-xpyL&index=12
This video shows how we can define an array parameter to create a parametric shading system.
