Hi folks,
I'm in a battle with Revit trying to work out hatch line weights. How the hell do I increase the line weight of the roof hatch in this image below. I want it to match the wall cladding hatch below which pops considerably more.
Thanks in advance
@Anonymous
Did you check the Surface pattern used in the Roof's Material?
@Anonymous
Yes there are several which can affect graphics...
We can keep guess or you can upload the model for checking ![]()
@Anonymous
Side Note (For Roofs, Use Model Pattern instead of Drafting)
That is the effect/behavior (faded pattern) on sloped surfaces...I do not think you can change or override itThis effect is also affected by
Changing line weights to suit different scales (thinner at smaller scales) should fix/mitigate the problem
If you are using too thick line weights and you disable thin lines...At Smaller Scales (1/50 >> 1/1000) the surface patterns might either blend to show a solid surface or entirely disappear.
see sample below (from your model at scale 1/20, 1/50, 1/100) ... Thin Lines disabled and line weights adjusted
