How to repeat a pattern accurately.
f.annoscia1XRNMD
f.annoscia1XRNMD
Good morning.
Following the suggestion of @barthbradley I realized this "modulo" in metric generic adaptive model family file and then I inserted it in metric curtain panel pattern based family file.
Now however I have difficulty mounting it. I have to get this drawing, highlighted in red.
I cannot get the pattern repeated precisely. Actually I will have to add other rods connected in the back part, but for the moment I would like to understand how to make this "flat façade" Then I will have to repeat the operation also for the roof, but it is simpler.
Thanks to those who can help me.
Well, first off, 1/2 Step is the wrong pattern.
Refer to this link to learn more about the different Patterns:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revit-M...
f.annoscia1XRNMD
Thank you. Which pattern do you think is fine? Using the triangular one I lose a part of the geometry.
f.annoscia1XRNMD
I saw that there was an error in the file, I corrected it, but I do not know which pattern to use, wich pattern is correct.
RDAOU
@f.annoscia1XRNMD
You need to look into Trusses. That is what he uses in 90% of his projects.
He is the father of "Less is More" ... so why would you want to over complicate things
https://forums.autodesk.com/t5/revit-architecture-forum/roof-of-mies-van-der-rohe-convention-hall-in...
Mies van der Rohe’s "Less is More" Convention Hall:
Barth van der Bradley’s "More or Less" Convention Hall:
f.annoscia1XRNMD
Good morning. In the meantime I have realized this support with metric curtain panel pattern based family.
Now I should compose it in a new project file, I think. Then I should make the roof and join it. I should therefore combine two different family mass in a single project, that is, roof and supports, which in turn contain the patterns. Is this correct? @barthbradley
@RDAOU, how did you make the howe trusses?
Thank you.
