How to render light through CLEAR glass globe pendant?
julie6V67T
Message 1 of 20
julie6V67T
Hi there,
I am trying to create a soft glow around these CLEAR Pendant Fixtures, but am not sure how to do so. See image and family attached. Thank you in advance for your assistance.
-Julie-
Replies (19)
Message 2 of 20
Soft glow you want? Use an Asset with a Self-Illumination Property.
NOTE: Self illumination only makes an object appear to glow. No light is actually cast.
Message 3 of 20
julie6V67T
There is not a self Illumination on Clear Glass, only on frosted or other materials besides Clear Glass.
Message 4 of 20
Okay?  So use an Asset that has the Property.  Or not.
Message 5 of 20
julie6V67T
I am sorry, I am not sure what you are saying exactly.
Message 6 of 20
syman2000
You may want to model the bulb inside the globe and add self illuminating material as @barthbradley mentioned. When you render in enscape, you will get the effect you are looking for.
Message 7 of 20
Change the Material that is listed in "Pendent Material" Parameter of the Family to a Project Material that has Self-Illumination.  Understand?
Message 8 of 20
The Light Source is positioned perfectly. I wouldn't move it to inside the globe geometry.  FWIW.
Create a New Material. It uses a Generic Asset that has Self-Illumination. It also has Transparency and Reflectivity. Play with all the settings until you get the look you want.
IMPORTANT CAVEAT: Make sure you give the Asset a unique name before making changes to it.
Message 9 of 20
julie6V67T
I cannot get it to look like that. I am not sure what I am doing wrong. Please see the family attached... Once I load it into my project it looks like a white globe, not clear...
Message 10 of 20
You posted the Family.  The Project is where you want to assign a Material to the Family's Pendant Material Parameter.
...just to confirm: we're talking about Rendered Views -- not Realistic Views; right?
Message 11 of 20
julie6V67T
Thank you for your help. I am getting closer. Do you know how to change the actual light to an orange color? I am trying to mimic an Edison Bulb. See updated family...
Message 12 of 20
Are you talking the Photometric Color Filter? Or, do you mean the Material Asset Color/Tint?
I'm thinking you mean this:
Message 13 of 20
julie6V67T
That seemed to change the reflection color to a yellow/orange, but NOT this white light itself. (Please note I really do appreciate you helping with this, hopefully we can get it solved soon)...
Message 14 of 20
syman2000
You have to modify the self-illuminating material to get the color you wanted. As well you may want to lower the emissivity value to make it show more of the color than the light.
Message 15 of 20
julie6V67T
Ok, I created an Edison bulb family for inside the globe pendant (Looks Great) however I am fairly new to creating families and I do not know how to align the light bulb sweep family to a reference plane so that it moves with the Drop From Ceiling Parameter. Should be the very last thing I will ask your assistance with. Thanks again! I have attached the updated family...
Message 16 of 20
Just Aligned and Lock it to a Ref. Plane.
BTW: Nice Job. Looking good!
@julie6V67T : Are you aware that you have 2 light sources in this family?
Message 17 of 20
julie6V67T
Great, thanks again for your help! I have attached the final family for future use for anybody that may need it.
-Julie-
Message 18 of 20
Why the 2 light sources?
Message 19 of 20
julie6V67T
Shall I remove this one? I am just worried because it took so long to create that I don't want to mess anything up and it is reading well in Enscape.
julie6V67T_0-1620244976578.pngjulie6V67T_0-1620244976578.pngjulie6V67T_1-1620245011791.pngjulie6V67T_1-1620245011791.png
Message 20 of 20
Hard to say. You have one that is controlled via a Photometric Web File and the other is not.  The Photometric Web one is coming into the Family by way of the Nested Lighting_INT_Bulb_Edison Family.  You could open this Family and check "Shared" and then reload it into the Parent Family -- and then reload the Parent Family into the Project.  After that, run a couple of Test Renders; one with the Nested Family's Light turned off and one with the Parent Family's Light turned off.  You turn them on and off through Artificial Lights dialog box.
