How to render 3D spinning animation in Revit?
taduykhang
taduykhang
Hi everyone,
My colleague handed me a Revit project file of a compressor rack. My boss wants me to create a video of that 3D model spinning around.
This task would be very easy to be done in Autodesk Inventor. But the problem is that when I convert that 3D model to .step file to be opened in Inventor, it has some serious issues with surfaces which is nearly impossible to be solved.
Therefore, I would like to ask is there a way to render spinning animation of the 3D model in Revit? Or is there a way to overcome this issue?
Thanks a lot.
blank...
Install Twinmotion and render in it.
hmunsell
you don't animate the spinning object. Make a camera path that circles the object and have the camera point to the center of the circle the whole time around.
or use TwinMotion 😉....
Howard Munsell
taduykhang
Dear @hmunsell and @blank... ,
Thank you guys for the instruction. I am able to use Twinmotion to render my video as I need.
My best gratitude.
