How to rename the hub/project name in Revit 2026
g_lumiaP4V8R
Message 1 of 1
g_lumiaP4V8R
Hi everyone,
I’m using Revit 2026 connected to Autodesk Construction Cloud (ACC), and on the home screen under Autodesk Projects I see “BT Works - BIM” as the main hub/project name.
I would like to rename it to something else, but I haven’t found a direct option inside Revit.
From what I understand, this might need to be changed in ACC / Account Admin or in the Project Settings, but I’m not sure whether this name refers to the organization (hub) or the project.
My questions are:
  1. What is the difference between the hub/organization name and the project name in terms of what Revit displays?
  2. Where exactly in ACC do I need to go to rename it (Project Admin or Account Admin)?
  3. After renaming it, do I need to do anything in Revit (e.g., clear the collaboration cache, sign out/in, restart) to refresh the name?
Thanks a lot in advance to anyone who can clarify the correct steps!
Replies (0)
