How to rename the hub/project name in Revit 2026
g_lumiaP4V8R
g_lumiaP4V8R
Hi everyone,
I’m using Revit 2026 connected to Autodesk Construction Cloud (ACC), and on the home screen under Autodesk Projects I see “BT Works - BIM” as the main hub/project name.
I would like to rename it to something else, but I haven’t found a direct option inside Revit.
From what I understand, this might need to be changed in ACC / Account Admin or in the Project Settings, but I’m not sure whether this name refers to the organization (hub) or the project.
My questions are:
  1. What is the difference between the hub/organization name and the project name in terms of what Revit displays?
  2. Where exactly in ACC do I need to go to rename it (Project Admin or Account Admin)?
  3. After renaming it, do I need to do anything in Revit (e.g., clear the collaboration cache, sign out/in, restart) to refresh the name?
Thanks a lot in advance to anyone who can clarify the correct steps!
Basam.Yousif
You can't make these changes from within Revit. You must be in the browser.
Close all Autodesk software Before you make this change, and not only you. Your entire company should be out of all programs (Acad, Revit, Desktop Connector and even non-Adsk that may have cloud files open such as Excel, Bluebeam)
Here is how you rename the HUB (But you must be the Account Admin):
Here is you rename the project (you must be the Project Admin):
