How to put a header in an RCP
Can someone explain to me what a header is and how to put it in an RCP? I'm supposed to put it in a bathroom between a GB ceiling and an ACT ceiling and then between two corridors. Any help would be fantastic.
Generally a header is a larger support above an opening designed to carry and distribute the load.   Its Structural and its sizing is governed by code.  You can use Beams or Walls  to represent it in Revit.
