How to show that the GB ceiling is at the bottom of the truss?
I am very new to RCps, and I am supposed to change a ceiling from 9'4 to "bottom of truss." Any help would be great.
You will need to edit the tag to achieve that – it currently shows the level of the ceiling, but Revit doesn’t know that that is the bottom of the truss.  Edit the tag family and change or add a label to show an additional parameter, such as ‘Comments’.  You can then manually add ‘Bottom of truss’ as a comment parameter for that ceiling.
Where's that information currently coming from? A tag?  If so, you could modify the Tag and swap out the current label for maybe "Comments",  then is the Project you would select the ceiling and enter  in the text "bottom of truss" into the "Comments" parameter field under Ceiling Properties.
