How To Put 2 Plan Names on a Sheet
dcnkzr
dcnkzr
Hi Everyone I couldnt figure out How To Put 2 Plan Names on a Sheet When I place 2 plans on a sheet.
Edit Sheet Title and type or copy paste the text.
rxi.gg
This can't be an automatic thing. As @ToanDN says, you must type it manually
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
