Filtered Hatch in walls
veritas99
veritas99
I am using filters to hatch walls and using drafting hatch. It wont align with walls when using that option under hatch properties
Are the drafting patterns set to Orient to element? You can also use Coarse scale pattern.
veritas99
Yes the drafting patterns are set to orient with geometry but nothing happens. I was told you have to set the materials to hatch and align but if I do that, all walls with that material change. I want filtered hatch so I can select certain walls.
What is the detail level of the view (coarse, medium, or fine)?
veritas99
fine
@veritas99 wrote:
fine
Can you show a screenshot of what pattern you would want?
