Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
How to place strip footing under basement slab?
3 REPLIES 3
justinbourne.design
265 Views, 3 Replies
I have a bearing wall that comes down to and runs along the middle of the basement slab, I am trying to apply a footing under it. Ideally it would be associated with the wall and have a 4" offset applied to it so it showed below the 4"slab, but at this point I'll take whatever works. Currently it shows up overlapping with the slab-
3 REPLIES 3
Make the footing type 4" thicker and join it with the floor.
Use the Structural Foundation: Wall to place footing under Wall and change the Wall's Base Offset to -4".
Actually, wouldn't this be the condition?
