How to place PIN if it is not in place ?
3 REPLIES 3
539 Views, 3 Replies
I have tried to place a pin using PIN tool but do not know how and where. I need to pin my created toposurface to CAD survey to be able to use it and view it with or without CAD file so it would not move accidently after I aligned them together. Please explain how to do that in steps. See in attachment toposurface sitting on CAD. Thanks
3 REPLIES 3
ennujozlagam
ennujozlagam
pick your cad drawings > pin > you can also change your cad drawings to background or foreground and see if helps. thanks
in reply to: ennujozlagam
Thank you ! I have pinned it but now I can not unpin it because I can not longer pick CAD file after it pinned. How to solve that problem ?
Redrunner92
Redrunner92
Check this toggle and ensure you have enabled selection of pinned elements.
