I have tried to place a pin using PIN tool but do not know how and where. I need to pin my created toposurface to CAD survey to be able to use it and view it with or without CAD file so it would not move accidently after I aligned them together. Please explain how to do that in steps. See in attachment toposurface sitting on CAD. Thanks
Solved by Redrunner92. Go to Solution.
Solved by ennujozlagam. Go to Solution.
pick your cad drawings > pin > you can also change your cad drawings to background or foreground and see if helps. thanks
Thank you ! I have pinned it but now I can not unpin it because I can not longer pick CAD file after it pinned. How to solve that problem ?
Check this toggle and ensure you have enabled selection of pinned elements.
