Hi Guys,
This is annoying - does anyone know what I'm doing wrong / if this is possible?
The sun path seems to be "locked" to the Revit internal Origin, which makes using the sun path COMPLETELY useless in 3D when the Project Basepoint isn't set to 0,0 (in our case it's 38.9m in Berlin). Moving the Survey Point Up also does nothing.
Many thanks in advance!
Cheers,
M
Solved by maxx.blake. Go to Solution.
I agree with @barthbradley
But I think your problem is the way you set project point.
I think you have to use Relocate Project command from Manage tab - Position in stead to move project point.
Then enable Sun path and set ground plane at level in Sun Settings.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
TL/DR : Solved by restarting Revit
Good morning @barthbradley @kostask_oionei
Many thanks for your replies - I had tried this before and it didn't work...
However, after closing revit and opening it again (you've got to be f***ing kidding me right?) the sun path is in the correct position:
As I said, many thanks!
